Convert RPT to PDF online.
The following steps can be used to Convert RPT files to PDF files.
Step 1) Search for the file to convert. Click Browse option, the content on the hard disc will show up.
Step 2) Now, Select the RPT file that you want to convert to PDF and click enter.
Step 3) Now, Click on the convert icon. After waiting, you will have the ability to download or send through email.
An RPT file (*.rpt) is a kind of report file created by Crystal Reports and designed to be used with Microsoft Visual Basic. It may contain information from many different database sources and can be opened with Microsoft Visual Studio or SAP Crystal Reports. Now, if you have an RPT file and you need to convert it into PDF format, here’s one way.
First, you need to convert it into XPS format using the Microsoft XPS Document Writer included in Microsoft Windows. Open your RPT file with the program you normally use for this file like Microsoft Visual Studio. Once the file is opened, click “File” then “Print” or just press CTRL + P. On the next screen, select “Microsoft XPS Document Writer” as your printer then click “OK” or “Print.”
Select the folder where to save the XPS file then click “Save.” When it is finished, go to Online PDF Converter, upload the file, and click “Convert.” And that’s it.
