Convert SharePoint 2010 law office template into Excel 2010
My manager ordered me to convert a sharepoint 2010 law office template file into Excel 2010 format. Which software will be useful for this purpose?
Hi Brenda Willey,
You can convert a SharePoint 2010 law office template file into Excel 2010 format; first select a range of data into a table. Then, Excel will show you an extra button to “Publish and allow Sync” to SharePoint
If you want to synchronize Excel 2010 with SharePoint 2010, you need to install Excel 2007 add-in. You can download this add-in from the mentioned link:
http://www.microsoft.com/en-us/download/details.aspx?id=9345
Just click on above link. And click on Download button, then installation starts.
I wish this solution may be helpful. Thanks!
Best,
Fenster Maxine
