Convert short English text book for children in to PDF
I downloaded a word format short English text book for children. What software will be useful to convert word document into PDF format?
Hi tammy,
GOOD Day,
why ain't you trying microsoft 2007/10 for converting your word file to PDF.Because microsoft has embedded pdf feature in 2007 and 2010 package.You can installed your pc and get enjoy easily for conversion your expeceted file for various purpose. I think you are getting another problem.you can use pdf converter free pdf converter free.
you also can download word to pdf or pdf converter . or direct online converter using convert word 2 pdf , pdf online.
BEst of luck
Here’s a different way of converting your Microsoft Word file into PDF document using Google Docs. To do this, you must first have a Google or Gmail account because this method needs accessing Google Drive. If you don’t have one yet, create a new Gmail account and sign in once the account has been created.
Go to Google Drive Web Interface to upload your Microsoft Word file. Click the Upload button, select Files, browse and select your file, and then click Open to upload it. See image.
You will see a window at the bottom-right corner of the page displaying the status of the upload. Click Settings then check “Convert uploaded files to Google Docs format” and “Confirm settings before each upload”. See image.
Once the file is uploaded, right-click on your file, point to “Open with”, and select Google Docs. See image.
In Google Docs tab, click File, Download as, and select PDF Document (.pdf). Browse to the folder where you want to save the file and save it. See image.
And that’s it. Your Microsoft Word Document file has now been converted to PDF format without purchasing new software or installing a new program. It’s all free straight from the cloud.
