alwyn white
20 points
Posted on - 04/07/2012
Hi
I have purchased various songs in the iTunes store. As these are coded in Apple's M4A or M4P format, the titles can normally be played only in iTunes or with an iPod. I would like to convert the titles to MP3 format.
Thanks
Convert titles from the internal format to MP3
Songs downloaded from iTunes are protected and you'll need a to use a converter to make it an mp3 file. I suggest you use Protected Music Converter free trial version but if you find this converter suitable for your needs, you can have the full and registered version for $24.95.
The installation procedure is very fast and easy, no complicated configurations or whatsoever, just the usual browse file and open procedure.
To download the free version, try this link PMC v1. 7
To purchase the registration code, please visit the developer's online store and your code will be delivered instantly!
Hope this helps
