Convert vb to c++ or c#
Posted on - 04/30/2013
Hello. Is there anyway I can convert my VB to C++ or C#. I honestly would prefer to convert it to c++ and C# is the second option. I don't want to loose all my data and I also don't want to spend much if there are software or applications required for me to do so and is there any way to re-convert it if it has been converted?
