Convert Videos In 64bit VLC Media Player In Windows 8
I have .webm and .mp4 video files that I want to convert. I do not have any extra software for conversion. How can I achieve this for .mp4 and .webm videos in a VLC media player in windows 8?
There is an option to convert videos to the VLC media player that most people don’t know. VLC media player is rich in features and capabilities and converting videos is one of them. To do this for .mp4 or.webm file or any video file for that matter (supported by VLC), follow these steps:
• Open VLC and click on Media option, which is the first one available at the top. And then from the menu shown click on Convert/save.
• A dialog box will appear and click on the add button. Add your file to convert and then click on convert/save button at the bottom. A new dialog box will appear and then under the profile section, select whichever you want. And click on start and your video will start converting.
And your video file is converted! That is all.
Since you don’t have any video converter on your computer and you only have VLC media player, this media player can already help you convert your WebM (.webm) and MP4 (.mp4) video files. VLC media player is a media player that is capable of converting videos into another format. If you haven’t updated yet to the latest version, download the latest VLC media player.
Once the latest VLC is installed, start VLC media player then click “Media” and then select “Convert/Save” or press CTRL + R. On the next screen, in “File” tab, click “Add” then load the video you want to convert. Next, click “Convert/Save.”
On the next screen, select a profile from the dropdown list. Once a profile is selected, click “Browse” then navigate to the folder where you want to save the converted video. Enter the name of the converted video and click “Save.” Click “Start” to begin the conversion.
Wait until the conversion is complete and that’s it. The duration of the conversion will depend on the length of the video and its screen resolution or screen size.
