I'm trying as much as I can to convert various VOB files that I have on my PC to AVI format, but I am getting confused on all the sections which includes the bitrates and resolutions.
Are there any simpler ways to do this?
Please let me know.
Convert VOB File to AVI Format
VOB or Video Object is a container format that can store digital audio and video, DVD menus and subtitles. It is also the same format used in DVD-Video files.
But this file cannot be played on some digital devices. AVI or the Audio Video Interleaved is from Microsoft which make it possible to play audio and video together.
The easiest way to convert your VOB files to AVI is to use the freeware VOB to AVI Converter. This is a free version so you don't need any activation keys to use it. So, this is really simple. To convert the file, follow the steps below:
1. Download and install the VOB to AVI Converter on your computer.
2. Start the program and then click the File button and select the files that you wish to convert by clicking on the Add Files button.
3. Choose the Output format such as AVI. Just select from the drop down list.
4. Click Browse to configure the path of your output media file.
5. Start the conversion by clicking on the Convert button.
6. When its done, you can now view the output AVI file on where you saved it.
There are many software that is capable of converting AVI and VOB file format, choose any of the following and just simply install in your computer and start the conversion.
1. Prism Video File Converter – This can convert common media file format such as avi, wmv, vob, flv and more. It can convert a single or even a bunch of media files. It can also convert Direct Show codec to AVI or WMV format.
2. Wondershare Video Converter Ultimate – A converter, ripper, burner, downloader and an editor in one.
3. WinX Free VOB to AVI Converter – Designed for converting VOB to AVI files with divx and xvid.
4. FreeMake VOB Converter – This tool will allow you to convert VOB to AVI, MKV, MP4, FLV, and more.
5. ArcSoft Media Converter – It can convert ausio, video or photo file to all formats.
They also have instructions on how to convert VOB to AVI in simple steps.
points
Hello Arthur,
There is also a techyv link that will provide you some good softwares for your purpose.
What is the best video converter?
points
Wondershare UniConverter (Video Converter Ultimate) comes with tones of features like converting videos in 1000 different formats, Burn videos in DVD at Blu-Ray quality, downloading videos/songs from over 1000+ sites, mirror cast, image/GIF editing and lots many other at this cheap price is very incredible.
This is the master piece which comes with all of this feature mention above in just $29.95 per year.But here only for you Get 30% off and $5 Cashback. Read More.
At this price point you will never ever find something similar like these which converts and download videos from 1000+ sites to 1000 different formats at super fast speed.
