ringitpelos
Posted on - 08/14/2011
I want to convert data from some website to PDF. I need some short and some long web content with image. Sometimes it’s have big table. Sometimes I want selected web content to convert.
What is the right way to convert this type of data?
Hurphy
Convert Website data to PDF
There are many softwares to convert direct from webpages to PDF but most of times these softwares cannot meet with our requirement's. You need to follow the steps to convert your data from Web Pages to PDF with 100% Accuracy and completion. First of all copy your required data from Web page to MS-Word if any Pic or graph involve you can insert it via Insertion of a Pic on Drawings toolbar no give proper format to your data. Now you can convert it from Word to PDF or it would be better if you will user PDF Creator Software to create you PDF files now create a PDF File and Paste all the data from MS-Word because MS-Word can reduce data size and correct the spells so its better option for you.
