Hello Techyv Experts,
I installed Real Player for my Mac computer. In Real Player, we can convert videos from one format to another. But when I convert videos to .wmv format. The converted videos sound quality is not good as the original one. Help me to convert wmv to Real Player Mac with Quality.
Thanks in advance
Convert wmv to real player Mac
Hello Gene
You should know that after converting a video from format to another and a loss of quality occurs then unfortunately it is irreversible.
So to prevent this mistake in the future here are some tips:
1. Make sure before you start the convert to check the goal file if it is set to be converted with full quality of lower quality, that can be done in the Manu where you chose the goal File format.
2. Using free software to convert videos is not a good idea because this freewares offer only a limited amount of quality, I recommend that you buy a video converter, any purchasable one is good enough.
Hi Gene,
The video and sound quality of a certain video will vary on the type of video format it was set. Also, another factor that can affect the quality would be the codec of a certain video file. If you want to ensure the quality of the converted videos, you should check and verify the type of format you choose. The following list below are the type of format hierarchy ranging from the highest quality to the lowest video quality.
From highest to lowest video quality: 1) MP4, 2) MKV, 3) XviD AVI, 4) WMV and 5) 3GP
Ware
