Convert Word Document To Fillable Form
I have to conduct a survey. I want a fillable form for that. Can you tell how I can convert a Word document to a fillable form?
You will need Adobe Reader on your PC.
• Open the Word document you want to convert to a fillable form.
• Give print command or use Ctrl+P.
• Select Adobe PDF as the printer and click print. A dialog box appears for saving the file. Save it.
• Your file will open in Adobe Acrobat editing mode. Now you need to convert it to a fillable form.
Select Tools->Forms->Create.
• Few questions appear. Select use the existing file->use current document.
• Acrobat will try to recognize fillable fields. It will set decorative lines on the fields it finds fillable. Correct and set it manually.
• Select Preview to view the form or Edit to make changes.
• Save the form.
