Convert XML Document To HTML Document
I want to convertmyXML document to an HTML document i.e. a web page. What are the steps I need to follow to convert it into a web page?
You need to follow the given steps-
• Open the library where the XML documents are present.
• Right click on the file you want to convert.
• Select Convert document->From XML to web page.
• The Create Page From Document dialog box appears.
• In the location, browse site where you have to create the web page.
• Write Page Title, Description and the URL of the page.
• In the conversion process, select any one out of Create this page Now or Create this page in the Background.
• Click Create.
Notifications
