Converting audio from wma in a Mac
70 points
Posted on - 04/28/2013
Hi friends,
I have a problem with my mac, it seems it does not support the WMA extension for audio files so I have been unable to listen to audio files with that extension, I don’t know if it a problem with my audio codec or my player.Â
Whenever I try to play audio files with that extension I get an error message that the file cannot be played.I was wondering if somebody could assist me with the problem and if you could please recommend a good audio conversion tool that I could use to convert the files to a compatible format.
