Converting Feet And Inches To Centimeters Theoretically
I want to learn how we can convert feet and inches to centimeters on paper? I know how to do it on the calculator, how to do it on paper? Is it a few step method or not?
It is quite understandable why you want to learn about doing the conversion of feet and inches to centimeter on paper. Many times we don’t have calculators around, so it is beneficial to learn it. Yes! It is a few step method and very simple. The steps are:
As I foot is equal to 30.48 centimeters, and 1 inch is equal to 2.54 centimeters, so we find the distance d in cm by adding the above. Suppose you want to convert 3feet+2inches to centimeters, then
D(cm)= 3ft*30.48 + 2inch*2.54
= 96.52cm
