Converting html to pdf code using java programs
HTML are usually in codes, using these source codes, can these source codes be converted from html to pdf code in java programs? Is this functionality advantageous for the developer?Â
To turn HTML to pdf code using a Java system, I suggest that you use Adobe Acrobat and Adobe plugin suitable with a web browser. This system enables you to save any web page and turn it to pdf format. All you have to do is to visit the formal Adobe web site, obtain and stimulate Adobe reader on your computer, just click next to create an adobe plugin (this performs an important part of transforming HTML web pages to pdf using internet explorer) when the installation is finished, release web browser and right click and select the HTML web page you wish to transform, click ''convert to Pdf'' to finish the procedure.
