Converting iso files to exe files
Is there a way to convert ISO files to exe?
If so, what software can I use for this?
Best Answer by Mehdy Blancha
Answered By 5 points N/A #160661
ISO file can not be converted in to exe file as both files have different platform of execution. Better use software Power ISO to execute your ISO files.
Its very easy to find & Install power ISO software.
Answered By 5 points N/A #160662
ISO files cannot be converted to EXE because the file formats are of a completely different structure. However, if you store the ISO file on a compact disk it can be accessed as an EXE file. In order to do this you must download Daemons tools and burn the installed file using Nero.
Answered By 0 points N/A #160660
It is impossible to convert the ISO file into Exe. These are totally dissimilar in the structure and pattern. But you can use the ISO file as Exe by storing the file in a compact disk. To do this, download the Daemons tool and install it. Open the file with the installed software and burn it through Nero.
Answered By 0 points N/A #160663
You can't convert ISO image format into executable file (EXE).
Because these are two different types.
Thank You.
