Converting jpg to vsd files
Hi guys,
I am a designer and I am looking for a quality solution to a problem that I have been having in converting jpg files to MS visio documents of the vsd format, I understand that vsd is a proprietary file format so there are not many tools out there that can be used in managing it even though it is widely used. What I would like is a quality software utility that can help in converting jpg files to vsd.
If anyone can recommend a good option please do, thank you.
