Lara Barkey
50 points
Posted on - 12/03/2012
Hi there! I have capture my son last birthday using my digital camera, and I want to sent it to his aunt. But, it's too large to send thru email. How should I convert my video into smaller video mb using Ulead DVD MovieFactory 5 Plus or total video converter?
Converting large video to Smaller video using mb converter
Hello Mr. Barkey.
You want to choose between 'Ulead DVD MovieFactory 5 Plus' and 'Total Video Converter'? Both of these are very good video converting software. But I would suggest you to use total video converter. This is a very good software and also easy to use. You can convert very big files with it. It can also convert HQ videos. You can select the converted video format and quality. You can make it a low quality video as mp4 file.
On the other hand, ulead dvd moviefactory is actually used to make slide shows with photos. It is better to use this as music file converter and movie maker.
I hope this will help you to select a converter. Thank you for your question.
Hi Lara Barkey,
You can split your video into many smaller video by using Ulead DVD Movie Factory 5 Plus. Follow these steps:
– Select your video in Media Clip list
– Drag Jog Slider to where your smaller video begin and press F3, or drag Mark-in to the beginning point
– Drag Jog Slider to where your smaller video end and press F4
– Redo these steps above until your large video trimmed into smaller ones
Hope this helps
It is a good way to make videos small in size. You can use any converter software such as Free Video Converter, Any Video Converter and much more software as your wish. Just use .mkv format. These formatted videos are good quality and small in size also.
I use Any Video Converter. It has easy video convert utility.
1. It supports many video formats such as .flv, .swf, .avi, .mkv and many kinds of mobile video formats.
2. You can edit video using this software. You can change the resolution, sound etc.
Download link: http://any-video-converter.com/
Also you can compress videos using “Advanced Video Compressor”. That also helps to make videos smaller in size. This software makes video compressed. You can also resize the video without any problem.
Download link: http://www.winsoftmagic.com/compress_video.html
In both way, you can make videos smaller sized and send easily.
