Converting MKV files to iPad2 format
Please name free or economic software to convert the MKV files to a format that can be played in iPad2.
There are many softwares that you can use to convert mkv video files a format that can be viewed on an ipad which is the MP4 format, but I will suggest that you use the MKV to MP4 Converter.
-Experttechyv
A file with a .mkv format is a Matroska Multimedia file. It offers support for a vast number of various subtitle, audio, and video compression formats and is actually not aimed for a wide scale media content distribution. It is a kind of video format that’s normally utilized to hold numerous video data tracks in one single file. The recommended media player that’s mostly used to play this kind of video format is VLC media player.
And since .mkv is not your ordinary video file that most video converters support, you need a video converter that supports this kind of format and can convert to a format that is supported by iPad 2. iPhone, iPod, and iPad all supports .mp4 video format. So that means, your .mkv file needs to be converted to .mp4. To do this, you can download .MKV to .MP4 converter which is available at .MKV to .MP4. It supports Windows XP, Windows Vista, Windows 7, and Windows 8. It also provides a Mac version for Mac users.
Thanks Expert Techyv and Sharath Reddy, for your impressive remedy. All of your remedy was good, but Sharath comment’s was the best, I think so for presenting singular guidelines. Sharath, I agree with you about the VLC media player as well with other opinion too. You also informed me that, me .Mkv files need to be converted .mp4. Which I have downloaded . MKV to .MP4 from your available provided link. Thanks Sharath, for helping me to convert any type of video format to MP4 video! I’d learned a lot from you. After free downloading, now I begin a new lifestyle! All my favorite songs are now played in my iPad.
