Converting my own Hand Writing into a Font
Hi experts,
Various Fonts are installed in my computer, but i would like to know how do i convert my own handwriting into a font on windows?
Best Answer by Pajarillo Classy
Answered By 0 points N/A #108806
Converting your own handwriting into a font in windows could be simple. Installing new fonts, click start then control panel then click at the folder either appearance or fonts then double click you will see many fonts then on the top right there is file click on it.
You will see install new font. Double click then you will see a drives list, click on the driver that you need.
In the Folders you pick the folder, double-click that contains the fonts you want to add. Under List of fonts, click the font you want to add, and then click OK.
Answered By 0 points N/A #108808
You can convert your hand writing into a font. To do this follows these steps.
  • Get a white computer paper.
  • Write complete ABC (capital), abc (small), 0-9 numbers, characters, and complete The Quick Brown fox's line with a pen.
  • Write is straight line.
  • See sample below.
Alphabet and numbers
  • Scan your hand written paper
  • Upload your scan image on http://www.yourfonts.com/upload.html
  • Yourfonts.com will convert your uploaded image to font.
  • You can done
  • Download your font and install it in your PC.
