Converting PDF file to Excel file
How can I possibly convert a PDF file to Excel directly?
I have tons of PDF files with tables that needs to be edited.
I basically need to change some values – numbers and words.
I've tried looking for possible solutions in the internet already but I can't seem to find a free and effective way to do it so,
I hope you can help me.
Thank you.
Answered By 0 points N/A #103275
Hi
Its very easy to convert PDF file to Excel, you can do by many ways
1. You can do this conversion by online links, a lot of websites are there to convert PDF files you can convert in those sites by submitting your PDF files and it will convert files and you will be given your email so after converting them they will send them to your email. You can use these links
These are well known sites from which u can convert PDF to excel and type of files also.
2. Or else you can download from these sites, install in your computer and you can convert how much files you want for your works and you can save in your computer.
These are the links from which you can download and covert into excel
Hope this will help you.
Thank you
