Converting PDF file to MS Word in MAC
Hello guys!
Your ideas will be a big help.
How should I convert PDF files to MS Word in my Mac computer?
I need some lesson plans and students’ activity sheets, so I made several downloads from a website.
I’m a school teacher in middle school and I get ideas from the web to make it easier for me to teach.
I have MAC OS and have difficulty with it since I’m not familiar with the MAC System.
What things or steps can you suggest so I could use my MAC without difficulty?
Best Answer by ASSADUZZAMAN
Answered By 20 points N/A #106825
Hello Archibald,
To convert your PDF files to ms word, you will need a software called free PDF to word convert.
As the name describes, the software is free and therefore you can download for free from the internet.
You will just need to access the following url and download it from there.
Or you can alternatively use the online converter which will enable you to browse the location of your file and then convert to ms word.
The converted document will be editable and therefore you can make changes to it like any other ms word document and then you later save it as PDF or word if you like.
Regards
Mahesh Babu
Answered By 15 points N/A #106826
You can use the PDF to Word software From Wondershare to convert your files in Mac. Just purchase it from iTunes and install it on your Mac PC. This will let you convert your PDF to Word files very fast and accurate while preserving the original contents of your files.
And also, if you want to know anything about Mac, just simply go to Apple website. They have some tutorials from Mac basics to Advanced. To start with, just click on the link below:
Mac Basics – Information regarding Mac PC
You can also search in Google for whatever question you have on using Mac.
Answered By 590495 points N/A #303880
If you’re on a Mac PC and you need to convert PDF files to Microsoft Office Word document format, the best way is to do it online. Try Convert PDF and Other Documents to Word. This tool will convert your PDF file (*.pdf) into Office Word document (*.doc). If you need to convert to the DOCX format (*.docx), try Convert your Documents to DOCX.
Both tools support PDF files they just differ in the output format of the file. There are four ways to upload the file to the tool. First, is to upload the file directly from your computer. Second, is to upload via URL. Third and fourth options allow you to upload via Google Drive and Dropbox.
Because you are converting a PDF file, you can enable or check the “OCR” option. When you are ready to convert, click the “Convert file” button.
