Converting PDF files to another format online
Hello!
I need help with converting my files to PDF.  I want to convert some of my files to PDF with the best quality and security available.
I need to know how I could convert them and if it’s possible for me to edit them online.
I hope you can help me.
Thank you.
Best Answer by Stephen_Lee
Answered By 0 points N/A #111346
Hi Martin John,
      Yes, you can edit your PDF File and turn them to be the best quality and security available.  You can try using PDFescape.  See the illustration below.
Using this you can be able to edit little changes on your pdf files such as hiding our personal contact numbers or if you want to put some annotations on your page with sticky notes.  It's free and will enable you to do some protection for your password on your PDF documents in the web browser.
Now if you want to edit the text , you have to convert your file to an Excel format( you can use the BCL Research) this is for a very difficult editing,  or a word document ( you can use stanza version )depending on its content.
Hope this might help you.
Thanks
Answered By 10 points N/A #111348
Hi
The question topic and the question that you asked give completely different meaning. However according to your detailed question not the topic I think you need to convert your files in to PDF format.
There are lots of ways that you can convert your documents into PDF.
Here is a one site that I found out,
https://www.freepdfconvert.com/
About the security, actually none of the online converters are not 100% securing. And also there is no way of editing the file online
I you want to do it secure and editable. You have to use an software to convert it.
Thanks
