Converting from PDF to MS Excel
Hello everyone! I have a very important statistical document which is in the Portable Document Format (PDF). But I want to convert this multi page PDF file into Excel 2007 spreadsheet with the possibility to set field by field the columns headers of the of the resulting Excel file. What software should I use? Thanks for the help!
Answered By 0 points N/A #182332
Hello Lucas!
If you’re out of time and budget please visit any websites the offers free converting options from one format to another.
Please visit this link >>>> PDF TO MS EXCEL.
You don’t need to have a membership log-in. Just follow the simple steps to convert your pdf file to usable excel format.
1.       Select the button “Select files…” and browse for the location of your file.
2.       On the empty field/textbox under “Email converted files to: “, please type your email.
3.       Select the file format “XLXLS/XML.”
4.       Click “Convert” button.
5.       Login to your email and download your file.
