Converting Real Player Video File to AVI
How can I convert Real Player video file to AVI? Can I convert them in real Player or should I download some conversion software?
Hi Charles,
There are a number of software products that can convert real player files to avi format. Here is a list of some programs that may interest you:
1. RealPlayer Converter – This can convert RealPlayer files, AVI, MP3, WMA, MOV, and other media files to your desired format. The converter also recognizes iPod formats. There is a Basic RealPlayer and an Advanced RealPlayer. I recommend the Advance version because you have more format conversions.
2. Real7ime Converter – This was made specifically for converting RealPlayer files to other formats.
3. Total Video Converter – It converts real player files to AVI, MP4, Quicktime, iPod format, and other media formats. There are two versions of this software: the first is a full version that promises quick conversion time and to more formats; while the second version is a free download that is more limited in conversion choices. The free version has the capability of converting real player to AVI files.
If you’ll go back to the old versions of RealPlayer, there is no option to convert a video unless you install a video converter. But with the recent release of RealPlayer, installing a video converter is no longer required. That’s because RealPlayer is now capable of converting videos to different formats and it’s not only limited to videos but audios as well.
Besides playing and converting video files, it can also convert audio files to other formats. And not only that, the audio of a video can also be extracted and save in your preferred format. RealPlayer can convert media files from FLV, 3GP, MP3, MP4, WMA, AVI, WAV, MOV, WMV, and RM formats and convert them into MP4, MP3, WMV, WMA, 3GP, QuickTime, AAC, WAV, RealAudio, RealMedia, and RealVideo formats.
Download the latest version from RealPlayer Free Download. It supports Windows XP Service Pack 3, Windows Vista, 32-bit and 64-bit Windows 7, and 32-bit and 64-bit Windows 8. It requires Adobe Flash Player ActiveX 11.0 and higher and QuickTime 7.5 and higher. In case you got confused, Adobe Flash Player ActiveX is different from the usual Adobe Flash Player.
Click Adobe Flash Player ActiveX to download the file directly from Macromedia.
Notifications
