anonymous
7060 points
Posted on - 06/20/2011
Is there a video converter that lets you set the output video by its file size?Â
For example, I want the converted video to be a 150 MB file, 700 MB file, etc. If there is none, is there a way, guides or manuals maybe, of getting the desired file size of your converted video?Â
Please help.
Converting Videos focusing on final size of the file
There are no video converter exist in which you can set the output video by its file size. There are many video converter available on the web that allow to convert videos in different categories I.E mpg, 3gp, flv or avi.
Converted video size depends upon the category of conversion and quality of the video file. If you want to convert the DAT file or AVI file, the quality of that video is good and after conversion they can take large capacity of the disk.
Although, you can try Any video converter software which are best to convert audio and video files in less size.
Take care.
Kate
j.paul
5 points
When converting the Video, some converters show the expected size of converting file.
You can change fps of the video or audio quality to bring the converted size to the desired value.
It also depends on the format to which you want to convert.
You can use Cowon Jet Audio, it has a built in Video Converter.Â
