ms.server
Posted on - 09/20/2011
What is the best protection cover I use for a MacBook Pro that will not lessen the computer cooling system? Because the tendency in some cases will act like an insulator. They can cause the computer to retain more heat, and therefore make the fan run harder.
Camzie
Cool and Effective MacBook protection cover
There are actually a lot of protection covers that you can use for your Macbook. Quality comes with a higher price. So if you want the best for your Macbook, price should not matter to you. Have you tried checking from Apple what they can suggest for your protection cover? The best thing that you can do is search online. Try to check reviews regarding a specific type or brand of that certain protection cover. Verify if their protection cover is made of a material that will not serve as an insulator, thus lessen the computer cooling system. I have a protection cover in my laptop as well; just an ordinary one and I don’t see any problem using it and I don’t think it lessens my computer's cooling system.
