Cool Smart Card Reader for Mac for Testing Projects
I need to test applications for different clients which makes use of smart cards.
I'm working with my Mac computer.
What I need is a cool smart card reader for Mac which I could use for my current and future projects.
Please suggest to me the best and cost-effective smart card reader for Mac.
Best Answer by Baker Mich
Answered By 5 points N/A #146070
The "SmartFold" SCR3500 mini USB reader is a fully ISO7816 compliant contact smart card reader that's perfect for use in a government, enterprise and home application areas.
  • Full speed USB 2.0 (12.0 Mbps)
  • USB Bus powered device
  • High-speed performance
  • CCID compliant
You can buy it from apple store or from Amazon.com, Here are the links:
SCM SCR3500 Smart Card Reader
Check the prices.
Answered By 5 points N/A #194987
Hi Sherry,
I would suggest you having an iAuthenticateâ„¢ Smart Card Reader, Which would help you with its cool features.
It’s now available for a pre order, I hope you get the best.
Following link would get you there.
It’s specially designed for Mac system and approved by US government as well.
It also includes a license to Thursby's PKard app for FIPS 140-2.
Hope this helps.
Thanks
Baker
