olisamuels
10 points
Posted on - 03/15/2012
I need your opinion about HSF, I have enough budget for Cooler Master Hyper 212+ or Deepcool Ice Blade GS.
Which one has better performance?
Or is there any better option with same range budget?
Hey Olisamuels!
First off here’s some features that they both have and you could look at them in the following links
I believe that you should base your fan type to the type of processor you have thought both of the products
You mentioned above does support a lot of new socket types and processors. It would really depend on what kind of processor you have in your computer.
Though looking at the specifications that you would find in the sites of the product.
It seems that the Cooler Master Hyper 212 + is much more better than the other one.
Hello.
Actually, you can't go wrong with either HSF. Both use heatpipes, are about the same size and have big fans that move a lot of air without making too much noise. However, based on several reviews on the net, the Cooler Master Hyper 212+ is known to perform excellently for its $30 price tag. The Deepcool Ice Blade GS, however, only gave a satisfactory (not excellent) performance for its low price. One review also states that the Deepcool Ice Blade GS has the danger of colliding with RAM that has high heat spreaders.
Since both HSFs are rather huge, I would suggest you measure your casing carefully to determine if either of the two would fit. Consider the components that surround your processor and see if any might get in the way of the heatsink.
So, in conclusion, I would say the Cooler Master Hyper 212+ is the better buy between the two.
