Cooler Master TCP 612 launch date
Cooler Master will launch the TCP 612. When the Cooler Master TCP 612 is gonna come ? Is there an official launch date ?
Hi Melanie
Cooler Master shows their new products at Computex last June 5-9. One of the products is the Cooler Master TCP 612.
The Cooler Master TCP 612 will be launched this August. TCP 612 has a 120mm single fan. The noise and the airflow information for the TCP 612 are not yet available. TCP 612 has 4 6mm heatpipes, a flat vapor chamber, nickel plated copper base, and aluminum alloy fins. The dimensions are 5.7 x 3.11 x 6.5 in and the heatsink is 4.7 x 4.7 x 1 in.
Here are the photos of the Cooler Master TCP 612:
Hope you will find this helpful.
Cheers
