The copy design dialog so that I can unselect/fix the problem
Please help me to solve this problem. I am trying to do a copy design on an idw. Spent about 30 minutes selecting what I want to copy and changing the filenames to what I want the new files to be. Checked/changed all the directories to make sure the new files are going to the correct folder. I check and double-check that the filenames are correct. When I am satisfied, I click "OK". VE works for a few seconds, and then I get the attached "Error 1091".
The file does not exist in the specified folder and cannot be checked out from it.
I choose OK and it totally cancels the copy design. All of my edits are lost without even an explanation of what was wrong. That is not good. Spend another 30 minutes doing the same thing again, and gets the same results. AAAARRRRRGGGGHHHHHH. Can someone explain this error message? Why does it cancel the copy design? It should show me which file is the problem, and go back to the copy design dialog so that I can unselect/fix the problem. I am using Vault 2011, update1 here.
