Copy error from my computer to USB
I had a problem while copying some movies in my computer to my cousins USB mass storage because he can't watch the full movie, only the first 20 minutes of it. So he tried copying other movies from other computers to his USB and it works fine.
I think there is a problem with my computer that seems to limit others when copying files from it. This already occurred twice to me with another USB. So I think I’m the one with the problem not the USB.
Does somebody have an idea on what could be the problem in copying files from my computer.
Best Answer by michaelR
Answered By 0 points N/A #114621
Hi Dear,
Actually this is a mysterious problem. This problem is faced by more or less maximum computer users. Your main problem is coping data from your computer to USB devices. You also mentioned that you faced this kind of problem twice. Also your cousins copied things from other computers without any problem. So here it is clear that your computer USB is ok also your cousins USB cable is ok.
I think there is no problem at all. In future if you face this kind of problem randomly re-install your Windows.
Hope you understand now.
Answered By 20 points N/A #114622
Hi Andy,
There are things to consider why you have difficulty to copy movie files from your computer.
First, the movie file is corrupted, the movie file did not finish download process, incomplete movie file, and interrupted download.
And most likely your computer is infected by a virus or Malware.
Please update your Antivirus and proceed to scan your computer. You may also install Malwarebytes to scan malicious files, viruses, and Malware.
If no virus is detected, most probably your movie file is corrupted.
LhanaPong
