Copy Hyperlinks to MS-Word Automatically
Asked By 440 points N/A Posted on -
I used MS-Word 2010 to copy paste URL’s from different websites. But when doing it, all the hyperlinks for each copied URL disappeared.  So I have to link the URLs one by one. How can I copy then paste the URLs with hyperlinks automatically? Please send some solution. Thanks.
Answered By 75 points N/A #107194
Hello Harry,
To retain the hyperlinks to the urls you are copying to an ms word document, just copy the links as you have said but then go to the end of each link and press ENTER on your keyboard. You will see the url underlined and converted into the hyperlink format.
Otherwise, when copying the url, ensure that you choose the option for 'copy hyperlink' and not the normal 'copy' so that when you paste it in the word document, it will appear as a hyperlink and not normal text. In this case you will not have to press enter on your keyboard, unless the url is not pasted in the hyperlink format.
__
Regards
Lee Hung
