Copy of magic1.exe to temp executing file failed
Hello Troubleshooters,
When I try to install the Magic application in the computer, I got this odd error message. I do not get anything else from the error message. However, I have lot of space in the drive. I have attached the error image please do the needful. Thanks a lot.
Error
Copy of magic1.exe to temp executing file failed, please ensure you are not running low on disk space.
Answered By points N/A #191338
Mostly, it sounds like you’re having permission issue running the program. So this trouble is appearing.
In order to fix this issue, you have to run the program in administrative privilege. This part of Windows Vista, 7 and 8 is really amazing that doesn’t allow programs to access the disk file(s) without having permission.
Right-click on the launcher of the game and select “Run as administrator”. If prompted, select “Yes”.
But you must have an administrative account to perform this action, no normal users can do it.
Now, you should have been able to run the game perfectly.
