This copy of Windows 7 is not genuine
Hi all,
Hi all,
Hello Mr. Ivan,
“This copy of Windows is not activated. Click here to activate Windows now.”
That is the reason whenever you restart the computer; you are prompted to enter a product key. The reason again that Windows 7 has either lost activation status or functionality mode is reduced to minimal.
Now to resolve the issue you may choose one of these three options, which may prompt for activation after 10080 minutes if the product key is not valid.
(R) Windows Script Host Version 5.7 generates the following text if the updates fail. The only way to skip this issue is only by performing windows updates once the activation is completed.
Click Start and then type command prompt in the search box, Right Click Command Prompt and select an option Run as administrator.
You can contact the Microsoft via telephone, to activate your window 7 if it’s really a genuine license key used to install your OS.
To check if your OS is genuine go to control panel and click the system.
You must see the genuine logo in the page.
You can also validate your windows, just click the link below. Microsoft Windows Validation
Hope this can help.
HI
According to your question there is another Techyv link which is explained well about this . Go that page too to get more helpful information to fix this issue.
