Copying data from one informix database to another
How can I copy a data from one informix database to another without using LOAD? Is there a script that I can use in doing this?
From one server you have to UNLOAD data to a text file, let's say data.txt (example a table with 2 columns and 2 rows)
Content of data.txt will be
1111|AAAA
2222|BBBB
Now using awk or insert manually  and replace pipe (default separator) depending on number of rows.
The data.txt file should content the following:
INSERT INTO table_name(Column_A, Column_B) VALUES('1111','AAAA');
INSERT INTO table_name(Column_A, Column_B) VALUES('2222','BBBB');
Now rename data.txt TO data.sql
Go to iSQL -> Query Language -> Chose Database -> Script -> Choose data.sql
and Run.
If you are avoiding LOAD because of an error, in my experience is because:
1.- Index corruption. Drop Table and create it again without indexes. Load DATA. Create Indexes.
2.- Number of data does not match number of columns. Use Pipe ( | ) as a separator.
3.- End of line. DOS files and UNIX files are different, check End-of-Line terminator.
