I have this error when I want to copy some photos from Falcon Camera to my SD Card. I can see the photos perfectly and I don’t know why I cannot copy them. Any solution for this error ? Please help me to fix this once and for all.
Thank you !
Copying Files
Copying “20130507_141739.jpeg”from “FalconCamera” to “extSdCard”
Error
0/1 items, 0.0/1.4 MiB
0Bytes/s, 0s remaining
The item “20130507_141739.jpeg” Could not be read.
Stop
Copying fails from Falcon Camera to my SD Card
If your camera says that the file cannot be read then I think there is no way you can copy the file. But it’s odd though because the picture is viewable in the camera and yet you cannot copy it as if it is corrupted. It is also possible that it is your camera that blocks the copying of the file.
Check the properties of the image and see if there is something that directs to the file’s permission or security. If the camera provides a setting for the file’s security, change it in a way that will allow you to copy it in your memory card. If there is no such option in the camera, check if there is a way you can connect your camera to your PC so you can try if it is possible to transfer it directly to your computer.
If you can directly connect your PC to your camera with a USB cable then do so. After this, see if you can transfer or copy the picture to your computer. If this is successful, just copy the file to your memory card.
