I copied an album from my pc to my galaxy s, but the tracks are not in order and there are duplicates? I don't get it because I just copied it once. Shouldn’t they be in the same order they are in the pc?
Copying tracks from pc to samsung galaxy s
If you are using USB to connect, the phone will act as a mass storage media or a portable hard drive (removable disk) and thus it should be easy to drag and drop your music files. Use explorer, select your music files, copy or drag to your media folder on your removable disk folder.
You have to set it up by going to Settings – Wireless & Network – USB Utilities and after enabling it connect your USB cable to the system. Click on both icons on your computer and phone that pop up and allow USB connection. Have the CompanionLink and Dejaoffice softwares installed for proper sync too.
If you are using Wi-Fi, installing and using File Expert will help.
