I would like to buy an extra camera. I would like to know more about Nextbase In-Car Cam 402G. What are the specifications of this camera? How much is it in the market? What are the available ports does it have to be connected on desktop or laptop? Is it rechargeable or battery-replaceable operated? If it can be connected using USB, can you show me how to do this step-by-step? What are the system requirements to make this work? Is it bundled with any photo editing tools?
Thank You!
The core benefits of buying Nextbase In-Car Cam 402G
Hi Marco, The NextBase In Car cam 420g specs are:Â
Full HD 1080p video recording at 30fps, Inbuilt GPS module, Advanced Wide Dynamic Range technology, 2.7 inch 16:9 LCD screen, 140 degree wide view angle, 6G sharp glass lens, F/1.6 aperture, Inbuilt G-Sensor, Data protection, Motion detection, Inbuilt microphone, Inbuilt battery provides essential backup, Manual emergency recording, HDMI and AV video output, MOV video format, Loop recording if the SD card is full and the earliest files will be overwritten automatically for continuous recording, 3 Mega pixel sensor resolution, Micro SD cards (class 6-10) support up to 32GB,12V-24V DC compatible, Dimensions: 107 (W) x 61.5 (H) x 37.5 (D) mm, Weight 100g
It has USB port, And HDMI port, The NextBase has built in screen, It also has USB port to display videos on your PC, The battery is rechargeable built in, It comes budeled with a software to view videos on both Macs and windows, It costs £134.99 on Amazon.
