Core Creative Cloud.exe application error
While I am working with creative cloud, I got this error image and then abort the application. I do not understand where I went wrong in the process. I tried to get help about nothing seems to correct or fix my problem. I have attached the error image; please do help me to rectify this error. Thanks a lot.
Core Creative Cloud.exe – Application error
The exception Breakpoint a breakpoint has been reached. (0x80000003) occurred in the application at location 0x045ecbe3.
Click on OK to terminate the program.
Answered By 590495 points N/A #188287
It’s quite confusing as to what Creative Cloud application it is you are using because Adobe offers many Creative Cloud applications. If you are using the Creative Cloud desktop App, I don’t see a compatibility problem either. The Creative Cloud desktop App works on Windows 7, Windows 8, and Windows 8.1. It also works on Mac OS X 10.7 Lion, 10.8 Mountain Lion, and 10.9 Mavericks.
If this is the first time you use Creative Cloud, close the application, restart the computer, and run Creative Cloud again. See if the same error happens again. It might also help if you will deactivate your antivirus temporarily while checking the problem with the application. Also, don’t run other applications while using Creative Cloud so as to avoid a conflict between the applications.
You should also check if you have plenty of RAM when using Creative Cloud. If your RAM is just enough to run Creative Cloud then it is not enough to make the entire system stable. Adding more RAM might help. You can also reinstall Creative Cloud.
