Core i7 ram info needed-urgent
There is a information I need to know about core i7 processor. What I need to know is exactly how much ram I will need to use this processor to its fullest potential.
I need the maximum performance for my CPU, hence it is necessary for me to know about this information.
Should someone know of this please let me know as quickly as possible.
Angelo Brent
Best Answer by Dona Ace
Answered By 0 points N/A #115471
Instead of the use of 2GB or 4GB even number Kits, i7 comes with odd number of stick that i7 uses 3GB,
6B and 12GB sticks.
For common users 6GB ram can offer good performance, but if you are a high level user of dozens of application I would suggest using 12GB ram.
It gives the user with increase in bandwidth and decrease in latencies at the same time.
So I would prefer the use of 3GB ram for beginners, 6GB ram by moderate users and 12GB by advanced users.
Answered By 15 points N/A #115473
Hello Angelo Brent,
The Intel core i7 processor can work hand in hand with a 64GB of RAM installed. But of course, you also need to make sure that your computer's motherboard supports that amount of RAM.
The ASUS P9X79 Motherboard supports the Intel core i7 processor and can handle up to 64GB of RAM. More information about the motherboard from the ASUS website.
Answered By 5 points N/A #115472
HI
Good choice Intel has this new set of fast powerful processors like the i7 series it depends to your everyday use. Memory comes 2GB 4 GB 8GB  up to 16GB depending on the class of Motherboard compatibility.
But it's better to have  8GB of memory  for more performance and it's more reliable to use.
