Corel Draw Graphics Suite X5 installation error
The following fatal error occurred during the installation of Corel Draw Graphics Suite X5- Service Pack 3 Update.
The message shows your update has been installed with the fatal error during installation.
What should I do now?
Can I get proper solution and instructions to fix this issue? I would be grateful to you.
Thanks in advance.
Corel DRAW Graphics Suite X5-Service Pack 3 Update
Your update has been installed
150_langen.msp—Fatal error during installation.
