Lloyd A Fox
10 points
Posted on - 11/18/2013
When I ran Remove Underlying Dups, the system told me it was going to delete 87 segments. It worked nicely!
Then I went ahead and selected the elements to do the joining, but the error below pops up. Have you any idea why this error displayed on the screen using Corel Draw in Windows XP Operating System. Any help would be appreciated. Thanks in advance.
Corel DRAW X3
Error: There is no node 1 of subpath 1 in this curve at the moment.
Corel DRAW X3 has encountered an error
I think maybe your segments have been deleted with remove underlying dups or maybe your software has get corrupted. You need to reinstall this software or download the service pack for your corel draw. If not you should try the new version of corel draw to fix this error and work again. There can be another possible mistake from your side in applying curves. I think you should clear out and see if your making a mistake.
Hope this help you out
