Corel PaintShop Pro X3 Installation Error
I have successfully installed Corel PaintShop Photo Pro X3 on Windows Vista. However, the program is not displaying in the list of programs. I re-installed it but my computer would hang. I tried to re-install it for the third time but it still not found in the list. Can anyone help me on how to install this?
The system cannot find the file specified.
C:UsersSteveAppDataLocalTempCorel PaintShop Photo Pro X31.5.1.001LangENCustomInit.htm
OK
Best Answer by ronOk
Answered By 10 points N/A #109091
After you finished the installation procedure, did it show that the Corel paintshop application had installed successfully? I will suspect that may be because of one of two things:
  1. Either the application that you are installing is corrupt and therefore it may show that the installation is successful but when you try to use the application it will not work. In that case you will need to search for another application that does not have issues from a trusted site.
  2. The problem may also be that the application that you are installing is not compatible with the operating system that you are using, and therefore you will need to check the system specifications of your operating system, and then download the right application that is supported by that operating system.
Thompson Locker
Answered By 0 points N/A #109093
I think this problem arose when installer extracts this program or software.
Cause:
1. Installer package may have the problem
2. Problem of your system
3. When program going to launch for first time you interrupted it
Sol.
My suggestion is to get a new software package from manufacturer and perform a clean installation with patient. After finishing installation and at first lunch wait until it shows whole program.
Answered By 0 points N/A #109096
Thanks a lot Guys
You both have been very helpful. This site Rocks.
