dave tuttle
60 points
Posted on - 06/21/2012
Hi, I was trying to download the CorelDraw.dll with the CorelDraw. But at that time I got a message regarding Error code 126. I didn’t find my answer in the help and the forum service. Can you please tell me what to do with this problem to solve? Thanks.
CorelDraw error after downloading a file
Do you mean failed to download Corel Draw?
1. The dll files may not be of order or that the System is not permitting such type of files. Or a link may be broken.
2. Try deactivating the firewall and the web shield with the antivirus shield all disabled for a moment. These may be blocking the DLL as it may have some unwanted software that harms the computer.
3. The software package that you are downloading must be from the official site and not from anywhere else. Such packages from anywhere contain malwares which harm the system.
4. Do not download a pirated version. Your Computer is infected then.
I think you are having problems with your .dll file. This is because either the file is corrupt or your antivirus is blocking it. Make sure when you download the .dll file then you turn off your antivirus and if it's not working then this link is for repairing your .dll file. I think you should turn off your antivirus and try repairing the .dll file and try reinstalling it.
Hope this helps
