CorelDRAW Graphics Suite 13 Application Error
Hi experts!
Is there any fix for this ? Has anyone made this before? Please help me.
Microsoft Visual C++ Runtime Library
Runtime Error!
Program:…CorelCorel Draw Graphics Suite 13 Programs CORELDRW.EXE
R6025 – pure virtual function call
CORELDRW.EXE – Application Error
The Exception
Unknown software exception occurred in the application at Location Ox7c812aeb.
Thank you.
Answered By 20 points N/A #108729
Hey Herbert!
I had also faced this problem a month ago. I search on Google for this problem but unluckily I did not found any solution. I discussed this problem with one of my friend, who told me that Corel DRAW Graphics Suite 13 needs minimum 1 GB of RAM and i realize that my RAM was 512 MB.
I upgrade my RAM and reinstall the Corel DRAW Graphics Suite 13 that really solved my problem.
I recommend you to upgrade your RAM and re-install your application, that will fix your problem and you can easily use Corel DRAW Graphics Suite 13
