CorelDraw GS X5 not running after completion of an update
Hi, I was previously using the CorelDraw GS X5 software on my windows 7 operating system. But after my windows completed some updates for the software, the software is not running anymore and says “Error code 193”. I did try some troubleshooting in the help option. Now I want to get some help from you. Thanks.
Answered By 0 points N/A #137898
    I also experienced the same problem to my Corel draw but different version, and didn’t find any solution from Google. So I made it by my self. The solution that I applied is to re-install the program and clear all the installed parts of the Corel to my computer. Although I know you don't like that but that fixed my problem. Some updates that you installed may not compatible to the version that you are using. Re-install the old version and that will fix your problem. If the error still there, you may also ask customer support from Corel draw to solve your problem.
