 If I open the menu> Edit> Insert Barcode
Here is the result that I get in the shape of error dialog. I am trying to resolve but unable to do this. Please provide some suggestion. Any help would be appreciated. Thanks.
CorelDraw
Failed to create object. Make sure the object is entered in the system registry.
CorelDraw X5 has occurred an error
I suggest that you should try a workspace reset. To reset your workspace, hold 'F8' while the program starts. Or you could repair the program:
1. Go to ‘Control Panel’.
2. Go to ‘Programs and Features’.
3. Then, right click ‘Corel Photo Paint x5’. Click ‘Repair’
If the error still persists, you should try to reinstall the program. The problem could be on the 'barcode.exe' and reinstalling might be the best solution for the error.
I hope this will help you to solve your problem.
Martine Paul
