CorelDraw X6 error 193 after updates
Hi, after some updates installed in my computer my CorelDraw GS x6 is not running. Rather then it is showing Error code 193. I reinstalled the software but nothing suited well. Now I am looking for your response to solve this problem. Please help me.
Answered By 590495 points N/A #154754
If this is the first time it happened with your CorelDRAW Graphics Suite X6, try rebooting your computer then try it again. If it doesn’t work, try doing a clean installation of the program again to restore it to its default configuration and possibly fix any corrupted files that may have already affected the application. Uninstall CorelDRAW Graphics Suite X6 then check your computer for any possible errors.
Use a disk utility application to check the system. For a much thorough diagnostics on the system, use a disk utility application like Norton SystemWorks, PC Tools Performance Toolkit, or Norton Utilities. Install the software again after this then check if this fixes the problem.
If your computer is running on newer versions of Windows then I don’t see any problem why the program wouldn’t work. CorelDRAW Graphics Suite X6 supports Windows XP, Windows Vista, and Windows 7. If you need to download its installer again, you may visit CorelDRAW Graphics Suite
