stevenchan
20 points
Posted on - 02/21/2012
Hello
I am sure that I’m having problems through a corrupted .dll file.
Until now I've observed that it has affected Windows Photo Gallery as well as Win amp.
When I want to open these programs I get the following error message:
winamp.exe Bad Image
C:Windowssystem32WindowsCodecs.dII is either not designed to run on Windows or it contains an error. Try installing the program again using the original installation media or contact your system administrator or the software vendor for support.
OK
Please help.
Thanks in advance.
Corrupt dll error on Winamp
1. Visit the DLL- files website and hit the Download hal.dll fixing. Clink on Save in the confirmation pop-up to start download.
2. Select the downloaded ZIP file enter to move the archiving usage on your machine and decompress the enter automatically.
3. Penetrate the decompressed DLL enter and then press Ctrl and C keys to copy it.
4. Click on Start Menu, then to My Computer open C drive to Windows and then the System32 folders. Push Ctrl and P together to paste the DLL. Yes to place the existing troublemaker DLL.
5. Go to Start and select Run type Regsvr32 C:WindowsSystem32hal.dll, flick OK and then OK This ok will register the file. Restart your PC.
lee hung
75 points
Just download the required .dll(windowscodecs.dll) files from the site below and install it whichever is required to get your applications run properly without any error.
Click on the link Download DLL file windowscodecs.dll in the above site address.
Hope this will resolve your issue.
Thank you Amoyo Agustin and Heiley Paint.
I followed your solution by downloading the .dll codecs from the internet.
After the reboot, the pop-up error message no longer appears.
Thanks TechyV!
