Bily robert
Posted on - 08/21/2011
Hi
Whenever i tried to empty my recycle bin i'm getting a msg saying
"nnot remove folder: the directory is not empty. "
i also tried "ChkDsk" utility also but problem still there,
Can somebody tell me way to solve this problem ? "
Patric
Corrupt files in recycle bin
Chkdsk is a Microsoft disk utility, which helps to verify the integrity between the system files and hard disks. If you are having a problem in corrupt files, this utility helps to sort out this problem. There are two user options to run this file. Â You can either tell the utility to fix all the problems in file system or thoroughly check the bad sectors in the disk drives. If bad sectors are found, it recovers the data in to a good one and removes the bad one from use.
For your problem, you can run this utility in the following way
Restart the machine
Put ‘chkdsk c: /f’ in the command Prompt
You will get a message whether you want ‘chkdsk’ to run when the computer reboots. Enter ‘Yes’
Then it will do the needful. However, this task will take longer time. You should also remember that there is a risk of data loss also by running this utility.
Regards
Kay
